FOR SALE 1973 Dodge Challenger
440wedge
Florida
History: Vehicle came with a 318 engine, automatic, and A/C. I purchased the vehicle from a private seller in 2011. Vehicle was purchased as a uncompleted project with no motor or transmission. I installed the rebuilt 440 Magnum big block motor, transmission, fuel system, etc.. Most everything on the vehicle was bought new, refurbished, or updated to current condition.
Body:
Green Go Paint, Custom Black Striping, T/A Fiberglass Hood, New Windshield,
New Front Bumper, 4 Point Roll Bar, Welded In Subframe Connectors, Taylor
Aluminum Battery Box, Red Optima Battery, Electric Fuel Pump / 3/8” Fuel Line,
Aluminum Radiator, Saginaw Style Power Steering Pump
Cragar Magnum 500 Rims (Front 15” x 6”, Tires: 215/70 R15)
(Rear 15” x 8”, Tires: 275/60 R15
Interior: New Classic Automotive Specialties Dash Panel Complete with
Autometer American Muscle Electric Gauges, GPS Speedometer Module,
New Dash Cover, New Steering Wheel, New Speaker Grille and Speaker
Motor: Estimated around 500HP
440HP Block, Bored .030 over, Forged Flat Top 10:1 Pistons
Balanced Polished Connecting Rods, SFI Certified Chrome Fluid Damper
Direct Connection Purple Shaft Cam (.509 inch lift, 292 degrees duration)
Ported/Polished 906 Steel Heads Oversized Valves (2.14 Intake,1.81 Exhaust)
Holley Street Dominator Intake Manifold, Holley 750 Double Pumper Carburetor
MSD 6AL Ignition Box, MSD Pro Billet Distributor, MSD Blaster 2 Coil
Hedman Hedders/Ceramic Coating ( 1 3/4” Primaries, 3” Collector)
Exhaust: Dual 2 1/2’” pipes exiting out the rear with Magnum Flow Mufflers
Drivetrain: Custom Drive Shaft, HD Pinion Yoke, Spicer Forged U-Joints, Front Disc
Brakes, Rear 11” Drum Brakes, Rebuilt Front Suspension/ MOOG Parts,
New Rear Leaf Springs moved Inboard, 8 3/4 Rear End Casting 489,
Sure-Grip - 3:91 Gear Ratio
Automatic Transmission: Torqueflite 727, Reverse Manual Valve Body,
J & W Performance 10” Converter 3000 - 3200 Stall,
9 Quart Chrome Deep Pan
B&M Super-Cooler Cooling System,
Hurst T-Handle Ratchet Shifter
VIN: JH23G3B207153
The vehicle has imperfections with normal wear and tear. The vehicle was never fully disassembled and restored. The body work and paint job were done by the previous owner. The motor runs good and transmission shifts strong.
Clean Florida Title No Trades
Vehicle is located in Lake Worth, Fl
$30,000 OBO
340challconvert
Parsippany, NJ
Brian
Welcome to FEBO from New Jersey and good luck with the sale.
Just as a suggestion, review the selling rules; you must list a price, and location and not post your e mail or phone. Contact is by PM
FEBO classified rules
Nice car by the way and Thanks!
440wedge
Florida
