I have a complete 340 6 pack set up for sale. Excellent condition. About 3000 miles on intake & 1800 on everything else. This is also posted on A bodies. Sold only as a kit. $4500 usd. Send a message if you are interested. Thank you
-LD6B Intake
- 4790 outboard(s)
-4792 centre carb (63 jets)
-6 pack air cleaner with K & N filter
-Base gaskets
-throttle bracket
-dump linkage
-return spring
-return spring bracket
-Coil bracket(s)
-ARP Intake bolts
-Idle solenoid & bracket (not the over priced re-pop but works 100% the same)
- Fuel lines
-Choke
- 6 pack carb bolts
-LD6B Intake
- 4790 outboard(s)
-Base gaskets
-throttle bracket
-dump linkage
-return spring
-Coil bracket(s)
-ARP Intake bolts
- Fuel lines
-Choke
- 6 pack carb bolts
