340 heads So it's been a while OMG great changes.
rumrunner70
So I've had this motor for quite some time came out of a 68 Barracuda Fastback four-speed car apparently was original motor to the car . Years later I finally tore it apart and just noticed the cast stampings one was a Z and the other one looks to be a O has anyone ever come across something like this also the Z also has a TA stamped in it.
The two locations in which you can find the casting numbers on Mopar cylinder heads. top and bottom of intake runner. Numbers matter more than letters.
LA Small-Block Mopar Cylinder Head Casting Numbers
2268341 – 1962-1967, 318 LA-series small-block, 1.84/1.56 valves
2465315 – 1964-1965, 273 LA-series small-block, 1.78/1.50 valves
2532080 – 1964-1965, 273 LA-series small-block, 1.78/1.50 valves
2536178 – 1966, 273 LA-series small-block,1.78/1.50 valves, early
2658234 – 1966, 273 LA-series small-block,1.78/1.50 valves, late
2658920 – 1967, 273 LA-series small-block, 1.88/1.50 valves
2658920 – 1967, 318 LA-series small-block, 1.78/1.50 valves
2658234 – 1967, 318 LA-series small-block, 1.78/1.50 valves
2843675 – 1967, 318 LA-series small-block, 1.78/1.50 valves
2843675 – 1968-1969, 273 LA-series small-block, 1.78/1.50 valves
2531894 – 1968-1970, 340 LA-series small-block, 2.02/1.60 valves
3418915 – 1970, 340 LA-series small-block, 2.02/1.60 valves, 63cc-73.5cc, T/A
3418915 – 1970-1972, 360 LA-series small-block, 1.88/1.60 valves, 65cc-73cc
3418915 – 1971-1972, 340 LA-series small-block, 1.88/1.60 valves
3462598 – 340 LA-series small-block, Trans-Am, 63cc-73.5cc
3671587 – 1973, 340 LA-series small-block, 1.88/1.60 valves, 65cc-73cc
3671587 – 1973-1974, 360 LA-series small-block, 1.88/1.60 valves, 65cc-73cc
3769950 – 1975-1978, 318 LA-series small-block, 1.78/1.50 valves, w/ air pump
3769974 – 1975-1976, 360 LA-series small-block, 1.88/1.60 valves
3769973 – 1975-1983, 318 LA-series small-block, 1.78/1.50 valves
4006335 – 1975-1978, 318 LA-series small-block, w/o air pump
4027591 – 1975-1978, 318 LA-series small-block, 1.78/1.50, w/ air pump
4006337 – 1976-1976, 360 LA-series small-block, 1.88/1.60 valves, 2bbl w/o air pump
3671587 – 1976, 360 LA-series small-block, 1.88/1.60 valves, 65cc-73cc
4027569 – 1977-1986, 360 LA-series small-block, 1.88/1.60 valves
4027163 – 1977-1986, 318 LA-series small-block, 1.78/1.50 valves
4027593 – 1977-1984, 318 LA-series small-block, 1.78/1.50 valves
4027594 – 1977-1978 360 LA-series small-block, 1.88/1.60 valves, 4bbl w/ air pump
4027163 – 1980, 318 LA-series small-block, 1.78/1.50 valves
4027596 – 360 LA-series small-block, 1.88/160 valves, 66cc-72.5cc
4027596 – 318 LA-series small-block, 1.88/160 valves, 66cc-72.5cc, High Performance
4041001 – 318 LA-series small-block, 1.78/1.50 valves, w/o air-pump
4041003 – 1976-1981, 360 LA-series small-block, 1.88/1.60 valves, 2bbl van and truck, w/o air pump
4071047 – 1977-1978, 360 LA-series small-block, 1.88/1.60 valves, 4bbl w/ air pump
4071051 – 1977-1980, 360 LA small-block, 1.88/1.60 valves
4071051 – 1981-1983, 318 LA-series small-block, High Performance
4100405 – 1979-1981, 318 LA-series small-block 1.78/1.50 valves, w/ air pump
4100408 – 1979-1980, 360 LA-series small-block 1.88/1.60 valves, 4bbl w/ air pump
4100409 – 1979 360, LA-series small-block 1.88/1.60 valves, 4bbl w/o air pump
4100409 – 1979-1980, 360 LA-series small-block 1.88/1.60 valves, 4bbl w/ air pump
4323302 – 1985-1986, 318 LA-series small-block, 1.78/1.50 valves, Fast Burn, 56cc -65cc
4323345 – 1983-1986, 318 LA-series small-block, 1.78/1.50 valves, Police, roller, 69cc – 77cc
4323475 – 1985-1987 318 LA-series small-block, 1.88/1.60 valves, 69cc -77cc, 4bbl
rumrunner70
I3-U-CtWH-Od3BNCKVhcuS717R-nriDmzS7iLFqFXsSRfbWPiqyLBQ3_9vIDzVK64Pfi2qDcADn_eePO1gYLroyFkp5sHojMlNptcCHotDHB6ICaWP5Fg57TRIapRkxw-9efjdU1Rp0grzzcLSCSwvAytVrLibydOvHxQhWd022X7X8j1IKbLOCmc7-NsesmXWtepXzeECi2_wzMB6O_2ziFkbPpeactCM5tU6sLj82KUmgmnk-o1UllFi5uq5067_yDHiV7C8am3MbjraF62z2dQYRDOV-fwf6swULu0b6LtlptOZ8Z23xxBieAl6uPY8decgc2wI7pCpQ1Kv0WGxgDFYyBeAPqfzhKDveATFPCPwmK7Tv_vMCBbWxp7AAs4qOoS6ZOTvm5FFGasBQLpDQ0HHU-os2C91LQ4uH7iTNR2kzeQ6CGQ2CgtFP_2SBoqfkIH7xeA2j-fVdVeQgh7hkww9wO2jnTPZwvjxJtG-iML4VIfpvueoTZoE9EmT-q_zxCFlha0NSXtpnYSs04ZD5vkzhjYyhOqzg1C7Z3A7iSnB0xa88HlGkcFk-UvT9sWkZPem7qW0N459dJVFlYbMHQ9Q98KUCY4OpDukTCToyjwa5JWygg4pXzVBCQ05-uQyIiw-AU3Wj50M_WLEJhpQjKvrpqn-BAcBADmssZg6kjx33NgRLbCyCuXoEkjzf7O7Jph5oSikBOf2g85gKtgWPWTkA-ngtA2r93yNr89Q46MZ031cVgBgIcIhSKiXWoE_8kGGQrYs3GTzkitm2khBadgitti0QIAON7S80ovMvx_vKabDCY9pOMEb6u5wRJBlxnEQrnfhqunkknn62RSQ_RqEEgF-Xr6NF-QZfZ-Q_4R7Uqq-M_Rzr2O8U2ctZ1QG8miPwpkZ8Bj5ZvppdZxjGO59BuH3qEG1HFfkHQSwl0HLWK5Q=w493-h657-s-no
