Hi All, here is a list of parts for sale that all came off my 1970 E Body Plymouth CUDA 440 and all in good condition. If anyone is interested in any of these items, please contact me for questions or any additional information. Prices do not include shipping.
Crank Shaft = $350.00
Crank Caps (5) = $75.00
Radiator = $350.00
Radiator Cap = $5.00
Radiator Hoses (top & bottom) = $25.00
Heater Hose (inlet & return) = $25.00
Water Pump Housing = $50.00
Water Pump = $40.00
Alternator 1 wire = $85.00
Voltage Regulator = $5.00
Distributor = $175.00
Coil = $25.00
Plug Wires = $35.00
Cat Iron Cylinder Heads = $500.00
Rocker Arms & Rockers = $150.00
Valley Pan = $10.00
Cam, Lifters, Push Rods = $150.00
Pistons & Rods = $150.00
Set of NEW 440 Source 30 over pistons = $500.00
Oil Pump = $50.00
Timing Chain and Gears = $25.00
Timing Cover (Chrome) = $25.00
A833 4 Speed Manual Transmission = $900.00
Drive shaft (recently balanced) = $125.00
Z Bar = $50.00
Flywheel = $75.00
Clutch/Pressure Plate/Release Bearing = $200.00
Rally Wheels/Trim Rings/Center Caps & Tires (15") = $600.00
Dana 60 Rear Axle shafts (Strange Brand) = $200.00
Edelbrock Intake Manifold (single plane) = $50.00
Edelbrock Carb (600 cfm) = $300.00
Edelbrock Carb (750 cfm) = $300.00
Holley Carb (dbl pumper) = $300.00
Original Type Head Lights (pair) = $90.00
Steering Column & Shaft (Parts Only) = $ 100.00
Round Edelbrock Air Cleaner (Chrome) = $ 50.00
Oval Air Cleaner Black with Chrome Stipes (New in Box) = $50.00
K Member with all steering linkage and torsion Bars (no Spindles) = $ 2,500.00
Manual Steering Box = $250.00
Gas Tank = $200.00
Mechanical Fuel Pump (Holley) = $100.00
Thermostat Housing = $5.00
Radiator = $350.00
Water Pump = $40.00
Coil = $25.00
Plug Wires = $35.00
Valley Pan = $10.00
Oil Pump = $50.00
Z Bar = $50.00
Flywheel = $75.00
Gas Tank = $200.00
