Moparparts
- Joined
- Nov 15, 2010
- Messages
- 1,067
- Reaction score
- 45
Correct 70 71 Rally Dash Instrument Cluster with 8000 RPM Tachometer and wood grain bezel. There are no broken needles or hot spots, and ther connector and bulb socket section of the wiring harness is still intact on the back of the cluster, so you could easily adapt it to your standard dash wiring harness if desired. The lens is very nice, and the gauge faces are not rusty, only some very light spotty discoloring on the white numbers and lines in a few areas. The clock cable is broken, but new replacements are readily available. One of the light tubes and one reset knobs are missing. The woodgrain on the bezel is fading and has light spotting. There are also 2 small drill holes on the bottom edge. A good original cluster that could be cleaned up and detailed for a driver, or would be a great cluster to restore. $425.00 plus shipping.
