FOUND Engine Mount Brackets Small Block
Steve340
New Zealand
I am after the two steel bent plates that connect a 340 block to the engines mounts.
I want LH and RH set.
I would need you to have PayPal and be prepared to go to the post office and ship to me in New Zealand.
If you live on the West Coast it would be good.
Rich Followell
Which set would you like?
Steve340
New Zealand
What would you want for them? Any set is OK so long as you are sure they are 340 mounts.
Unless the rubber part is mint you could take them off I only want the steel bracket.
Rich Followell
Well they are all for a 340, but after reading your message. I checked and found there is difference in the alignment of the holes. the aftermarket set matches the oem set that has the heat shields, but does not match the other set. It is narrow and the center bolt for the rubber mnt. is also different. My guess is that the 70 is not the same as later models
Rich Followell
Alright sorry, I have not gotten back to you sooner. my day job has kept me quite busy this week. But that's a good thing gave me some time to look a bit closer. the reason the aftermarket set is different is poor build quality they are to narrow to fit the subframe. I won't sell junk. So here's the deal if your still interested I want to keep one set. and sell one OEM set with the unused rubber mounts. the price is $100. So you need only to decide if you want the set with the heat shields or the set without. Thanks
Steve340
New Zealand
I will take the set with the heat shields thanks. Details are in the PM I sent you. Steve
