k member and steering box??? on 73 cuda
prairiedoghunter
eastern colorado
I was wondering what the differnce is (if any) between a big block and a small block k member? Everyone i've talked to says there is something differnt, but they can't tell me what
I have a 73 cuda that origionally had a 318 in it, I am looking into puting a 440 in it.
the car has a power steering box, however i was thinking about putting a manual steering box in it, any thoughts?
burdar
IOWA
The K-members are the same. You'll just need big block engine mounts. The Hemi K-members had a skid plate welded to the bottom that others didn't have.
the big block K had the skid plate as well which is the only difference , it just protected the deeper 6 qt oil pan , the 440 is a bolt in as stated above .
manual steering will also bolt on , you need a longer steering column as the steering box is about 2.5" shorter
prairiedoghunter
eastern colorado
now i was looking at the steering column a little bit, and got to thinking about when i changed the steering column in my 72 dodge charger.
in my charger the new column was too short. So after disasembling the column i found you could slide the shaft out longer. The shaft looks idintical to my charger's, so i was thinking it might slide also????
it can , the problem is there are nylon plugs through the shaft so it will collapse on impact , not nessisarily the best idea to break them though + how long is the shaft , you need to have enough engagement , having the steering fail while exciting may not be preferable . Personally I would look around for the correct longer shaft
jvcuda
upstate New York
Unless you are building an all out race car,I would keep the power steering.I kept it in my '73 cuda with a 440,makes it much nicer on the rare times I do drive it on the street.Just my .02 worth.
john
I go the opposite way , I far prefer the manual steering except for parking , way more road feel without the possiblity of over reacting
ram250098
Cookstown Ontario Canada
Not to take over the thread but will any Mopar power steering box work in a 73 Cuda or does it need to be for that year, it is a big block car.
AL
Good question , the steeringbox will fit , the column will connect no prob but the pitman arm is a different listing for 73-74 , as long as the box has an arm on it & it fits into the center link from above or below the same as the idler arm you are good to go
