Oil cap
i_taz
Pocono's PA
Hi All,
Looking for an oil fill cap that closes parallel to the 70 valve covers. The 'ears' have to be perpendicular to the handle but every one I found
point in the same direction even the Mopar ones. Maybe the hole in the valve cover is clocked wrong, AMD.
This pic is one sold thru a GM parts supplier and may have to do...
Show a picture of your valve cover hole. The hole on factory valve covers was at about a 40° angle from parallel. So a cap with parallel ears would install with the outer ears running parallel to the covers. Is this what you were looking for ? You didn't say the year or engine size though.
i_taz
Pocono's PA
Sorry, there RB valve covers. I thought they were all offset but I've seen some that weren't. The cast aluminum arent for some reason and AMD apparently dropped the ball but either way I thought I saw both types of caps before and now can't seem to find one that looks stock. Even Roseville only sells the one type...
