Thermosat housing with sending unit port
KMikk
I am in the process of installing a fitech fuel injection on a 340. Does any vendor make a thermostat housing with provisions for a temp sending unit. it needs to be 1/2" npt.
AUSTA
PERTH WA
If you are running a thermostat the Fitech may not get the right temp for self tune as the monitoring sensor may be on the cold side.
challenger6pak
True. It needs to be on the engine block side of the thermostat. You may need to drill and tap a mounting spot.
