1970 Challenge Window Bolts
Chuckin
Carlsbad, CA
I am looking to find the bolts that attach the window lift mechanism to the rear holes in the front window glass on both sides and the bolts that attached the lower horizontal track. I think they are numbered 22,23 and 18 and an actual picture of them installed would be great. Thanks! I have the
One more photo from the 71 Barracuda which should be close to a 70 Challenger as they use the same door glass.
Chuckin
Carlsbad, CA
Thanks and I will look for bolts as per the first diagram. In the picture above its confusing because the bolts appear to have a long smooth shank and then just a small threaded section at the end and I can find bolts like these so I will need to try the ones that are threaded for the entire length.
