K memeber difference?
01freeman
I want to know if a 6 cylinder K member will work with a 340. I have a K member from a 6 cylinder challenger and want to use it for my 340 challenger that needs one. If not what is the difference.
ramenth
Beaver Dams, NY
Difference? Mounts.
You can use that K if you want.
www.engine-swaps.com
Schumacher has kits that will allow you to bolt your 340 to that K. Put a bigger set of t-bars on it and you're good.
74 challenger
s carolina
ramenth is right,i would get a new k-frame.They are cheap but you got to do what you can afford.
01freeman
here are some pictures of my K member in my car is it a 6 cylinder or V-8 K member
bad440
Sudbury,ontario
Definitely a difference between 6 and 8, V8 does not mount to 6 cylinder K frame; one exception though if you purchase Schumaker mounts the V8 will bolt onto the 6 cylinder K frame, probably cheapest and easiest way to go.
I agree , this info is correct
