gran coupe john
OER carpet, looking for some feedback.
			Correct on both accounts! Mine was a great fit, just had to do some trimming. I got mine with the upgraded "Mass Backing", some kind of a rubber type backing and it was a big improvement over the jute backing.I believe all carpet kits come from ACC, best prices at rock auto.
That^^^^^^ right there!Lay it down on your driveway under the heat of the Sun.
I want to encourage you to use heat. Laying out the carpet kit (face down) on the lawn (just one example), in direct sunlight can do wonders. Come back a few hours later, when the carpet base is good and hot, one can press out those folds very nicely and get the carpet nearly perfectly flat. When it cools in the evening, pick the stiffer carpet up and gently place it inside. Repeat as needed.Got the OER carpet this week. Came in a box all rolled up. Got it laid out in my living room. There is some bad creases. Put some heavy books on the ceases. Trying to get it flattened out before installation. Any tips would help
