steering collum foam collar
JMB711
Spanish springs Nevada
Reassembling my 70 Colum, I did get the foam collar and other bits from Mancini racing. There are two foam collars in the bag I know where the big one goes but how about the smaller. I see no area in the old Colum where one might've been? I'll guess the 2nd one is for some other year and body style??
Thank you.
Thank you.
The larger foam seal installs between the outside of the inner shift tube, or 1970 lockout link tube if console shift, and the outer column jacket. Install it about four inches from the end of the outer jacket.
The smaller foam seal installs on the steering shaft between the shaft itself and the inside of the shift tube. Install it about two inches from the end of the shift tube.
Placement of the seals is not critical, just install the seals approximately as noted.
