73 Clutch Pedal Bezels?
quapman
I don't recall the later ones ever having bezels. (I've been wrong before, though!)
fk5aar
It would need the pedal dress up kit I would assume. Not sure if those years had that option either
Steve340
New Zealand
The pedal rubbers will need a small recess at the edge for the stainless bezel to fit down in to.
If you do not have the recess in the pedal rubbers they will probably get pushed off or catch on the soles of your shoes especially when you operate the clutch.
valkman
In the Triad NC
Here's a picture of the type of pads I have
Steve340
New Zealand
It is hard to know if they will fit but it looks good if they do.
My car has the pedal dress up kit and I like that little extra shiny bits on the pedals.
valkman
In the Triad NC
I agree, thats what I was going for. I bought a full kit for the gas, clutch, brake, and parking brake. That was before I knew it was a difference for 73 and 74 from the earlier years
Steve340
New Zealand
Yes they probably will and if not the B body pedal pads those bezels are designed for will most likely fit the E body pedals.
Steve340
New Zealand
Oops I ment to say don't think they will fit. The B body pads look narrower
They may be to small, hard to know from a photo. It is only $15 to find out.
You have the 70 - 72 tapered pedal kit and rubbers - correct?
Just make them fit by trimming your pedal pads. With the right tools and if you are careful trimming the pad metal is doable.
valkman
In the Triad NC
So are you saying the pedals on my car are are tapered. If that's the case I could just get some tapered pads
Steve340
New Zealand
70 - 72 have slightly tapered pads.
73 - 74 have the completely square pads.
The difference is fairly obvious once you recognise both types.
Post a photo of the kits you purchased.
valkman
In the Triad NC
I have a 73 Challenger that has the square pads as seen in the 1st photo I posted. I also have the bezels for the tappered pads. My question is will the tappered pads fit on the 73 pedals?
quapman
I have a 73 Challenger that has the square pads as seen in the 1st photo I posted. I also have the bezels for the tappered pads. My question is will the tapered pads fit on the 73 pedals?
I think the pedals themselves are all the same. Peel off your pads and take a pic.
