FOR SALE 1970 Challenger SE passenger door panel
71smoke
Chardon Ohio
1970 Challenger passenger side door panel. Black. Panel has cracks and scuffs, but is all there if you had nothing. Insert is pretty decent and reflector red part is good the bezel could use being redone. Carpet is crap only missing 2 of the clips for it. It is located in Hambden ohio 44024. $100 plus shipping. I only do postal money orders and ship usps or cash in person if you pick it up. Probably expensive to ship but will cut it up if someone only wants the unobtanium pieces.
6PKRTSE
Would you just sell the woodgrain insert and reflector with chrome bezel as my door panel is for power windows and I already have the door panel.
Yes I would cut it up
You don't have to cut anything. The carpet strip has clips that easily bend to undo it. The clips are worth saving. I don't believe they are available with reproduction carpet. The reflector is attached to the cardboard under the carpet. The wood grain insert has small nuts holding it into place.
71smoke
Chardon Ohio
I don’t want to risk breaking studs off. I place zero value to the plastic so if the inserts are all someone wants then they can unscrew the nuts. I will cut it up and the price is the same
