This Bad Ass Chrysler 383 Big Block Engine built by Performance Engines in Carmichael, CA would be the perfect powerplant for any street/strip or streetrod. Give your Mopar muscle car or hotrod a new life. This complete (air cleaner to pan) 400+ horsepower engine has a semi-rough idle and if running an automatic transmission, a mild stall speed converter is recommended. High performance 9.9:1compression runs on leaded or unleaded premium pump fuel. All componenets are new except for the original block, crank, rods and bare heads. Engine has less than 1,200 miles including break-in.
Specs:
3.380" stroke factory forged crank (polished, ground 20/30, computer balanced)
6.358 factory forged rods (fully prepped and balanced) with ARP bolts
New Keith Black flat-top pistons with valve reliefs.
Seasoned 2-bolt main factory 67 block - fully prepped, decked, bored .060 over
(4.31)
Factory 67 cast iron closed-chamber 915 performnce heads - fully prepped and
ported with stainless steel valves, milled to 74cc combustion
chamber
New roller rockers with Comp HP springs
New Comp Cams Magnum 280H hydraulic flat tappet cam - 480 lift
New double roller timing set
New Melling oil pump and Mopar Performance drive shaft
New Carter fuel pump
New Mancini Racing aluminum water pump housing with high-flow pump
New Eddelbrock Performer RPM aluminum airgap manifold
New Summit Racing 600cfm duel inlet carburetor with electronic choke and
vacuum advance
New Mopar Performance electronic ignition system (distributor, coil, module and
harness) with wiring setup
New Alternator ( 60 amp)
New pulleys and belt
New Chrome air cleaner and valve covers
New engine mount brackets
Hedman shorty ceramic coated headers
Winner of "Best Engine" award at Hang TOwn Car Show in 2011
Asking $3,800 OBO. Serious inquiries only - No Scammers!
Call 916-838-6227 and ask for Don.
Will also provide blueprint, spec sheets, receipts, build photos and test stand video
Specs:
(4.31)
chamber
vacuum advance
