FOUND 727 Kickdown Linkage
Cud@
Minnesota
Wanted - Kickdown pivot bracket assembly on driver side of bellhousing on 727 automatic transmission.
The engine is a 440 RB if that makes a difference.
704406
Shawnigan Lake B C Canada
Do you still need the linkage?
I have the complete 3 piece kickdown setup from a 70 383 727
Upper rod, upper bell crank, vertical rod, pivot bell crank and bolt, and lower rod.
I think I have a vertical rod from a 440 as well.
Let me know if you're interested.
Cud@
Minnesota
Hi,
Yes I am interested, do you have pictures of the parts you have? I do need the rod for the 440 RB as I have the rod for the 383.
