FOR SALE Fake 71 Hemi Cuda driver / project
Craig J
Racine, Wisconsin
Running driving car... starts, idles, drives. No leaks, doesn't overheat. Needs 1/4's changed for correct side marker lights.
Engine: 1500 miles on ring & bearing rebuild. 440, forged pistons, LY rods, steel crank, eddie heads, mopar roller rockers, fast fish rear seal... ancient TRW dome pistons are noisy when it is cold... no blow by, no leaks. eddie single 4 barrel intake with shaker base.
Transmission: wide ratio TKX
Rear: B-body width S60, OE Dana 3.54 gears, eaton tru trac, 35 spline strange axles, OE drum brakes
Other: Dakota Digital, Borgeson, wilwood front brakes, Tommy Chryco Shaker, USCAR, firewall forward is all AMD other than the OE flat hood converted for the shaker. Included but not installed are both AMD full 1/4's with correct the side markers.
Also included: Aluminum 540 hemi. Everything is new except the valve covers. includes OE iron manifolds, Eddie 2x4 carb intake and Eddie 2x4 Pro Flow EFI system, ARP studs, bullet solid roller, BAM lifters, 10.2:1 Diamond 4032 pistons, roller rockers, molnar crank & rods, plug wires, dual quad shaker base, etc.. short block is assembled but heads have never been installed.
I do not have the skill or place to do the paint work... time to let someone else dump time & money into this thing...
$60K for everything. not looking for trades.
craig.d.jorgensen@outlook.com if you want more info.
