loose door window
2darts
what would cause a door window to be loose in and out not up and down? winds up good and has no play when rolled up tight but as soon as you crank it down a little it has a ton of play.need help.thanks
sfort
Granbury,TX
There is all kinds of plastic inside the door attached to the glass. You are going to have to pull the door trim panel and look inside with a flashlight.
