Latest activity
  • Challenger RTA
    Challenger RTA reacted to KlsCuda's post in the thread Blown rear end? with
    Like
    Like
    Hi all ... update: I replaced the diff fluid with 80w90 and a bottle of motorcraft additive friction modifier. The fluid that came out...
  • MOPARMITCH
    MOPARMITCH reacted to heminut's post in the thread Disc brake conversion with
    Like
    Like
    Well, THAT was real helpful!
  • pschlosser
    pschlosser replied to the thread What carb size mopar 340..
    Mechanical secondaries are more sensitive to timing, and linkage changes, and can open too fast for the engine, causing a slowness in...
  • KlsCuda
    KlsCuda replied to the thread Blown rear end?.
  • Kansan
    Kansan replied to the thread Mopar convert.
    Welcome from Arkansas.
  • Kansan
    Kansan replied to the thread New member.
  • R
    rasmus westlin replied to the thread What carb size mopar 340..
    I gonna try and see if i can borrow from a friend and see. Why is it better to have a vacuum secondary? I feel the car has a quite...
  • D
    don selleck reacted to rasmus westlin's post in the thread What carb size mopar 340. with
    Like
    Like
    Recently bought a -71 challenger with a 340. Specs are 340” drilled 0.30 Eagle rods Keith black pistons Edelbrock torker 340 intake...
  • S
    Steve340 replied to the thread What carb size mopar 340..
    Can you borrow a known good carb of a friend to try it ? If the problem is gone you will eliminate the engine, ignition etc. If you do...
  • heminut
    heminut replied to the thread Disc brake conversion.
  • heminut
    heminut reacted to HPP's post in the thread rear height with
    Like
    Like
    Yep, from the factory, with equal size tires all around, the only E bodies that sat taller in the back were the AAR/TA twins. Everything...
  • S
    Steve340 reacted to mcauto's post in the thread New member with
    Thanks!
    Thanks!
    New member from Farmington New York, I own a 1970 Cuda 340 4spd slowly restoring to original condition. I will post some pics soon
  • heminut
    heminut reacted to MOPARMITCH's post in the thread Bluecifer 1970 Cuda B7 Blue Restoration with
    Like
    Like
    So I have been agonizing what to do about the destroyed dash pad for my '70 Cuda. The original owner had taken the dash pad out giving...
  • S
    Steve340 reacted to fast68's post in the thread Mopar convert with
    Thanks!
    Thanks!
    I think a lot of us are born into certain car makes depending on what our dad's were into, and then they become our favorite. I was born...
  • R
    I have this transmission all crated up and ready to ship...... Crate is 40x13x12.....141 lbs..... I can put it on a pallet if...
