Latest activity
  • D
    don selleck replied to the thread AAR resto.
    absolutely, pretty much everything on the car has been checked and haven't found much that was right. :lol: even the reconditioned stuff. 🙃
  • Xcudame
    Xcudame replied to the thread Lug Stud Recommendation.
    RockAuto (or Dorman 610103 part number)...
  • Xcudame
    Xcudame replied to the thread AAR resto.
    Keep us posted on what CNC says/does for you. Because anything less than .006" rod clearance will likely cause very bad things to happen...
  • Kansan
    I need to change out four left hand thread lug studs on the driver side rear axle on my Cuda. Apparently, someone has swapped out the...
  • D
    well rod to rod clearance specs at .0060 to .014. ranging from .000 to .030 to .007 to .002 not sure what to do with that at the...
  • Q
    Nice used original fan shroud part number 2998328. Fits 1970-73 B & E body with 22 inch radiator. Big block or small block. It has no...
  • Locomotion
    I've had great results with Rancho 9-way single adjustables. Cal-Trac appears to have used or still is using relabeled Ranchos. They are...
  • Locomotion
    Locomotion replied to the thread WTB Scrap headlight bezel.
    I have 4, details in PM.
  • maxb
    maxb replied to the thread rear height.
    I removed the leaf springs from the car, replaced all of the bushings front and rear and installed the new front perches with the...
  • pschlosser
    pschlosser replied to the thread 1970 CUDA 440.
    1. Rear End - The noise is likely something mechanical. It could be wear, a bearing, a U-joint, it may be something else. Those noises...
  • 1
    Hi! Please provide me comments on the following 4 issues that I have with my CUDA: 1) NOISY REAR-END I have a 3:23 ratio differiential...
  • pschlosser
    pschlosser replied to the thread A/C delete.
    The holes in the cowl firewall are the biggest cosmetic items that still haunt my car. I removed a dealer-installed A/C unit back in...
  • Katfish
    Katfish replied to the thread transmission 46RE OR 4L80E.
    I put in my 518 when car had a 340, drove it 5yrs, then swapped in a 5.7. Seamless swap to the Gen3 and runs great.
  • BSG
    Already have my 392 gen3 and the terminator x max. I want to go with the 46re but i'm concerned about the tv cable making the 4l60 or...
  • BSG
    i'll upload some pic of the grille how i got tomorrow, in the middle of welding floors and rockers on a 58 impala should be done with...
