Latest activity
  • Xcudame
    Xcudame reacted to moparleo's post in the thread Wheel Decode Help with
    Like
    Like
    As far as I know the 15x6.5" Rally wheel was not offered until 1975 and later. Download a 1971 Plymouth Factory Service Manual and go to...
  • Xcudame
    Xcudame reacted to Vaanth's post in the thread Wheel Decode Help with
    Agree
    Agree
    The pictured wheel showing the number stamps was made in 1975 at Motor Wheel plant # 1. This is a 15" x 6.5" Rallye Class I wheel, part...
  • Xcudame
    Xcudame replied to the thread 440 harmonic balancer looooose!.
    On the 906 heads, concentrate on the bowl area under the valves next to the big boss around the valve guides. You want the air/fuel to...
  • Xcudame
    Xcudame reacted to 6PKRTSE's post in the thread 70 challenger 383 radiator overflow question? with
    Like
    Like
    I have what I believe is a later A body over flow in my red 70 Challenger. It came on the car when purchased it. I just put it back on...
  • Xcudame
    Xcudame replied to the thread Magnum 500's vs Rallye's.
    On Year One 17" magnum wheels! That sucks! On their 17" Rallye wheels, I hope they get more in stock soon!!
  • Xcudame
    Xcudame reacted to Katfish's post in the thread Magnum 500's vs Rallye's with
    Agree
    Agree
    Always gotta ask the question, do you actually drive the car? 15 in tire selection is dwindling and expensive.
  • S
    Ok thanks for checking those cranks!! I’ll order a new balancer since this one looks like it seen better days. Thanks again everybody...
  • Xcudame
    Xcudame reacted to Cuda_mark's post in the thread heater box with
    Like
    Like
    IMO all of the value is in that front cover. If it's broken, $100. If it's not broken, $1,000. That's just because I've never seen one...
  • Xcudame
    Xcudame reacted to terrywalker's post in the thread heater box with
    Agree
    Agree
    Yes, it will work in other years non-A/C e-bodies. Here's what he's talking about non broken front cover. This is from my 71 Challenger...
  • Xcudame
    Xcudame reacted to Vaanth's post in the thread heater box with
    Agree
    Agree
    I have no real idea about the valuation in today's market(s). To me personally, not much, as I have a good one in each car, and a couple...
  • Ricks72Chlgr440
    Need to run a hard line from the mech fuel pump area to the side of the tank that would connect to one of the 4 tank vents tubes? What...
  • Xcudame
    Xcudame reacted to moparleo's post in the thread 340 piston options with
    Agree
    Agree
    Juan, since you insist on 10.5:1 cr, you will also need to find a steady supply of a good quality, 91 Plus octane fuel to keep the...
  • Xcudame
    Xcudame replied to the thread 340 piston options.
    Heck with aluminum heads, you might get away with mid-grade 89 octane!
  • DBAH
    Rallye Dash Instrument Cluster Gauges, Housing, Bezel and Lens Two switch panel bezels with backing Right lower dash trim Additional...
  • Xcudame
    OK, after measuring six crankshaft snouts where the balancer rides, I got between 1.529" and 1.530" with all closer to 1.530". I then...
