Latest activity
  • Xcudame
    Xcudame replied to the thread Core support.
    And be sure to run a fan shroud like @Katfish has!
  • Challenger RTA
    Challenger RTA replied to the thread Dash repair.
    Did they see what need repaired. Or was just off the cuff and see what sticks to the wall? Show us a picture.
  • Xcudame
    Xcudame reacted to Ricks72Chlgr440's post in the thread Core support with
    Like
    Like
    The only issue you may have is if you currently have an original radiator and then go to aftermarket. The aftermarket radiators do not...
  • Xcudame
    Xcudame reacted to Katfish's post in the thread Core support with
    Like
    Like
    Absolutely, that’s exactly what I did to mine. Just drill a couple new holes on passenger side and add some rubber bushings to take up...
  • Xcudame
    For those with a 70-72 Barracuda/Cuda a little shorter screw with captive washer. 73-74 are shorter yet with no captive washer.
  • Xcudame
    #10-14x.65" long Pan head Phillips.
  • Xcudame
    Xcudame replied to the thread brake clips.
    None of us is perfect, but as a group, we're pretty dang close. As a side note, I've not run the positioners or anti-rattle clips on...
  • Xcudame
    Xcudame reacted to Vaanth's post in the thread brake clips with
    Like
    Like
    The following is a correction and adjustment of post #3. The Kelsey Hayes floating caliper positioners retain the caliper guide pin...
  • Xcudame
    Like
    Like
    @floyd is correct. I have the pictures and description notes backwards for the two sets of part numbers. Everything else in my post...
  • Xcudame
    Xcudame reacted to floyd's post in the thread brake clips with
    Like
    Like
    @strycker @Vaanth I always appreciate Vaanth’s detailed and informative responses. In this case, I disagree on the 70 vs 71-72...
  • Xcudame
    Xcudame reacted to MOPARMITCH's post in the thread Bluecifer 1970 Cuda B7 Blue Restoration with
    Like
    Like
    Time for an update. I've been back from Vietnam for 2 weeks. Collecting body supplies and having the trunk lid stripped. Last spring and...
  • Matt68
    Which would you guys choose and why? does anyone have experience with the repro ones? I can only find one remake through Year One Parts...
  • Matt68
    Matt68 replied to the thread Dash repair.
    @Bret Schneider Thanks for the tip. Unfortunately, the local Fibrenew guy gave me an estimate of $600-650 for the repair, and it would...
  • mrmopar340
    mrmopar340 reacted to Katfish's post in the thread Core support with
    Thanks!
    Thanks!
  • M
    Only wanting the twin scooped hood. What kind of shape and what are you asking fot it?
