WTB 1970 dated cuda v-8 K-member
Torqueflite
ks
Hi guys. Hope everyone is well. I need a nice 70 cuda v-8 K-member if someone has one. PM me with details and price. Thanks and take care !!
ldr
W.Va.
I have several , but you live in Kansas if im not mistaken, im sure shipping will kill the deal or not im in wva do you need sway bar also?
Torqueflite
ks
Idr, thanks for the reply. Tried to P.M. you but your inbox is full.
gzig5
Mequon, WI
I've got one that supposedly came from a 70' Barracuda. How do I tell for sure? Also have one that is a bit dirtier that was supposed to be from a 70 Challenger. I'd sell either but don't know how to check them.
340challconvert
Parsippany, NJ
This may help;
K Frame Identification
There should be a small round or oval "coin" on the front with a 2 digit number stamped in it. That will be the K-Member part number. There is also a very small 4 digit number stamped near it. Those small numbers is the date. The date will be like 3229 = 322nd day of 1969.
Here's the 1970-71 K-Frame numbers
10 #2962010 Crossmember (K-Frame) 225 Engine
12 #2962012 Crossmember (K-Frame) 318, 340 & 383 Engines
14 #2962014 Crossmember (K-Frame) 426 Hemi w/ Skid
52 #3583052 Crossmember (K-Frame) 318, 340, 340 T/A & AAR, & 383 Engines
70 #3583070 Crossmember (K-Frame) 198 & 225 Engines
74 #3583074 Crossmember (K-Frame) 318, 340, 383 & (440 w/ Skid) Engines
76 #3583076 Crossmember (K-Frame) 426 Hemi w/ Skid
77 #3466477 Crossmember (K-Frame) 318, 383 & 440 (440 w/ Skid) Engines
A-66
Registry
This may help;
A-66
Registry
I am not sure that they all had the "coin". I have an original '71 383 and 340 that do not. They have the stamping but no coin.
340challconvert
Parsippany, NJ
Not all k-members had the coins though; some had the part number applied using what looked like a rubber stamp or stencil of some kind. (As per Barry Washington)
Torqueflite
ks
This one has the coin with 52 stamped on it. Thanks for the info!!!! Since this car has a bent up K-member from the accident, I should be ok to find a correct date member and replace the coin with this one or add it right? Not like I'm trying to fake anything.
340challconvert
Parsippany, NJ
I would not worry so much if you needed to add the coin to another k frame. Remember that there is also a date code on the k frame (left of center also) which may or may or may not match up time frame wise with your build date anyway. The 52 k frame was common; used with 318, 340 and 383 engines. You may get lucky and find one with the same "key" part number. Unless you are building a rare Mopar and are a stickler for originality; I would not worry. JMO
A-66
Registry
Torqueflite
ks
Thanks 340! I'm not going to beat myself up trying to find a totally date correct one as long as it's correct for the car. Thanks.
