FOR SALE 70 se rear clips
Are you making the corner ones as well? Complete set? 6 pieces for the corners and 5 pieces that go on the edge?
You mean 6 for the bottom edge correct?
That may be correct. Mine has been on a few years and I not %100 percent sure if 5 or 6. I was sent the pics I posted from a E body forum and its show 6 corners and 5 one that hold the edge on. Its cool your working on them. Much needed for alot of people. Thanks for doing them. Mike.
I will
Won't be long
Here you go all done and works better than oem
$199.00 BOTTOM 6 CLIPS
$99.00 FENDER OEM CLIPS
TEXT ME
253-651-2220
do you have any pic's you could post.
Are you going to need the clips and fender clips for your rear panel
Let me know
I'm in..let me know when you have them. I really only need 1/2 a set, in case someone else is in need of a similar mix
What do you need to get your panel on your car
Bottom clips
Fender clips
Let me know and I will work with you
