Misc Mopar Parts For sale-Mich
6PKRTSE
Engine:
1-used Blown 426 Hemi blower cam $ 100.00
1-used set 452 b.b iron heads $100.00
1-new 3.750 Eagle 8 bolt flange HEMI forged steel crank $500.00
1-used set of b.b. main cap & bolts $40.00
1-new P3690936 cam offset bushing kit $20.00
2-new P4876926 HEMI spark plugs (4 plugs per pack) $15.00 ea.
1-new Hemi/b.b. many cam & plug dowel pin kits all mixed together $40.00
15-new P4006767 b.b. / Hemi lifters $5.00 ea. $60.00 for all
1-new PD-17 Durabond b.b cam bearing kit $ 20.00
1-new P4529699 sfi approved b.b./hemi damper $250.00
1-used lot of misc cast iron exhaust manifolds, intakes, oil pans, alternators, starters etc.-SOLD
1-used 70’ 440 iron 4 bbl intake- $40.00-SOLD
1-used 70 4 bbl carb linkage & kick down $30.00-SOLD
1-used 70 440 power steering pump $40.00-SOLD
1-used 70 iron water pump housing $40.00-SOLD
2-used 70 440 upper & lower motor mounts $ 50.00 per pair-SOLD
1-used d.s. lower motor mount bracket $20.00-SOLD
1-used set of 4 groove water pump pulleys $ 40.00/set
1-used 440 oil pump $10.00
1-new set Speed Pro p/n R9771+5, 4” bore 1/16 1/16 3/16 ring set $40.00
1-new set Total Seal 4.310 bore 3.0MM scraper & expander set $ 45.00
1-used 440 valley tray $10.00
2-used sets of std 440 pistons w/ rings & pins $100.00/set
1-used set of 440 LY rods $100.00/set
1-used 440 distributor w/ vac adv. $10.00
Ram:
1-new 94-02 club cab body moulding $10.00
1-used 94-02 tail gate handle & hardware, everything but tail gate shell $40.00
1-used 94-02 front license plate bracket $25.00
1-used 94-02 day/night rear view mirror $25.00
1-used 76-93 B.B. truck trans cross member-SOLD
B-Body:
4-used Bullit style 68 Dodge hubcaps $25.00 ea.
1-used B-Body transmission cross member $40.00-SOLD
1-used chrome master cylinder cover $10.00
1-new pair of lift off hood brackets $60.00
E-Body:
1-used E-Body power Steering gear box $100.00-SOLD
1-used E-body 727, 8-3/4 driveshaft $100.00
1-used E Body trans cross member $50.00
1-used E Body heater core assy $150.00
2-used E Body rear leaf spring brackets $40.00
A-Body:
1-Used A body transmission trans cross member-$40.00-SOLD
Drivetrain:
1-used 4.0L Jeep auto trans yoke $ 40.00
1-used 727 trans yoke $ 40.00
Many other Mopar parts as well. The more I look thru the garage the more I have to get rid of.
Call 1-313-505-7948 Make an offer on all items. I have no use for any of the items & need to make room.
water pump pulley
Engine:
Ram:
B-Body:
E-Body:
A-Body:
Drivetrain:
you still have the water pump pulley or motor mounts, James
8 3/4 Drive shaft
Hi Can you let me know what the lengh of the drive shaft is from center of yoke to center.
I'll have to look. They may have sold with the last big batch of parts that another local guy bought.
It is:
44-3/8" c to c.
52-5/8" o.a.l. $100.00 plus shipping if it will work for you.
Did you also leave me a voice mail yesterday in regards to this driveshaft as well? If so, Sorry. I tried to call you back with the dimensions. I dropped my cell phone on the ground while digging out & measuring this driveshaft & now my phone is not working.
Looks like these were sold in the last big batch of parts that were grouped together on that package deal.
It is:
44-3/8" c to c.
James does it have the yoke with it..... if so is it 2 1/8 or the large 2 5/8
Thanks. And that other e mail reply that you say it is sold is that to me or something else.?
rumrunner,
Don't know if there is something going on with the forum or what, but I did not receive your P.M. with the the address. Can you please send it to me again? Thanks.
drive shaft
Jay l sent you another message ....not sure why you haven't received them. Doug
