A body will not work tail shaft extension housing to short.On 73 Challenger with 440, if i search for an A833 4 speed, do all “bodies “ fit each other? A body, B body, E body trannys?
Ok, so if seller says it has “dual shifter mount locations “ it will fit?A body will not work tail shaft extension housing to short.
B body will work as long as the tail shaft extension housing has the rear shifter mount. Lots of B body transmissions have both shifter mounts one at the front by the speedo gear hole and another at the end of the extension housing. B and E are the same overall length.
Any year E body
Yes.And if i find one from a b bod with rear shifter mount it will fit?
The B trans and the B-E one 0 really, have different transmission mounting pad locations. Be carefulThanks!!!
I will ask, but im sure drilling/tapping the holes is no biggie?Does the rear mounting pad on the tail housing have holes drilled for the shifter? And make sure it’s not an overdrive 4 speed aluminum case
It is not aluminum, and rear shifter mount has threaded holesDoes the rear mounting pad on the tail housing have holes drilled for the shifter? And make sure it’s not an overdrive 4 speed aluminum case
Disregard this answer as the holes were already drilled for your applicationIt’s harder than you think due to the nature of the style of bolts used to hold that shifter pad -a correct straight drill angle is very vital and so is the center center to center measurements. You could have a machine shop drill them for you for peace of mind.
All this time and you sell these!!?? LolDisregard this answer as the holes were already drilled for your application
send me more close-up pictures and your engine sizeNobody knows if this tranny will work?
I’ll have to ask for more pics…. Motor is 440Yes, I do fully rebuilt
What views do you need?Yes, I do fully rebuilt
Input retainer, main case part number, tell shaft photo part number and detailed picture of site cover. Spine count.What views do you need?
Spline count is above with the picsInput retainer, main case part number, tell shaft photo part number and detailed picture of site cover. Spine count.
