A bit more info would help, do you have a complete motor with mounts? what transmission are you running?On a 70 challenger, what is needed to go from 340, to a 440? I know there’s probably a lot of incidentals, looking for the basics other than the actual motors!
I have no more info, as i have not purchased the car…. Just wanted to get an idea how involved…. As i mentioned, car presently has 340 a/t, i would want to put in 440 4 speedA bit more info would help, do you have a complete motor with mounts? what transmission are you running?
Likely need to change the radiator, if you're using a 26" now the location of the hose connections are different, the torsion bars, p/s pump, exhaust the list goes on.
Tell us what the plan is and what you currently are running, and what you have for a motor to swap in
This is an involved swap. Not including the motor you will need these [arts from an E body:I have no more info, as i have not purchased the car…. Just wanted to get an idea how involved…. As i mentioned, car presently has 340 a/t, i would want to put in 440 4 speed
If you have a pretty fat budget, I would look at Blueprint Engines. I put their 408 (stroked 360 magnum) into my Duster and boy, at 465 HP and 515 torque it's a runner! A bit pricey but you can use all your existing parts to save the hassle of a big block swap. I did upgrade my torque converter and put Dougs Headers on.Thanks for the input guys!
