Fender Fitment 70 vs 71
money pit
I have a 70 Barracuda. I'm having problems finding original fenders for a 70. I found a set of original 71 fenders. Will the 71 fenders fit on my 70? Are the mounting points the same? The alternative is to buy aftermarket fenders, which I rather not do. Thanks
pschlosser
Santa Rosa, California
Sure, they fit. And if the 1971 fenders don't have the fender gills (a 1971-only premium option) they will look identical to the 1970 fender. In 1971, the front fenders came in two versions.
But I am a little fuzzy where it comes to the headlight end pieces of the grille. Because they screw into the fender sheet metal, I don't recall if those holes are the same location on a 1971 fender. There could be other differences I'm unaware of.
When you go look at aftermarket fenders, they do indeed list two different fenders for 1971, with, or without gills. I would expect if the 1971 standard fender were an identical replacement to the 1970 fender, they would be listed that way on their websites, and on the 2-3 websites I looked at, they are listed (the 1970 and 1971 standard fender) separately - as if they are indeed different products.
1971 Gran Coupe
They will bolt on but that is about it. The headlight setup for the 71's are four headlights and the headlight mounting buckets/brackets are totally different. And the grill is not even close. On a side note, I am looking for a pair of 71 barracuda fenders.
money pit
I didn't even think about the headlights or grill. Thanks
money pit
That's good to know. Thanks
tonysrt
I have a 71 Cuda that had a NOS 70 fender installed with a plate welded in with the gills. I eventually got a NOS 71 fender that I installed on the car. I remember vaguely a little work was done to fit in the 71 headlight bracket, but that was about 40 years ago.
