New Yukon 3.91 489 - Cranky Pants noisy
Titan1969
Orange County, CA
Thanks in advance for any advice.
I purchased a new Yukon SG 3.91 case 489 for my 73 Cuda and removed the peg leg 3.23. I have swapped diffs many times and never encountered an issue, except this time.
Install went fine no issues, I 2x checked end play, added Valvoline 80/90 gear oil and friction modifier.
On the maiden voyage of a few miles in a straight line the diff has no issues, no noise, however any turning...even slightest I get alot of grinding noise and bumping, guesses the SG clutches are grabbing to much.
I attached a video and Ill calll Yukon this week for advice
After my Dana gear change, things were clunky on corners.
Adding a 2nd bottle of the Ford friction modifier quieted things down.
I spoke with Yukon and here was there feedback. I only have about 10 miles on the new diff, so it may need more breakin time. Im also going to add +4 oz Mopar Friction modifier before my next drive and Ill report back.
__________________________________________
We offer the OEM style HD Sure Grip - the aggressive Dana Spicer style 4 pinion Powerlock. These are patterned after the OEM Mopar Muscle car limited slips, but with updated/upgraded parts such as a stronger nodular iron case, chromo internals, etc. And like the factory HD Sure Grips, they are on the aggressive side.
The "smooth" street version uses the same clutch pack design and stack up as the old 440 and Hemi cars - so it is prone to a little noise and some tire scrub on the street - it is a true authentic reproduction - not a watered down design.
USA Standard Gear Powr Lok Positraction for Chrysler 8.75\" | ZP PC8.75-SMTH | RANDYS Worldwide
We also offer an even more aggressive version that is tailored to the pro touring / drag race crowd. It's not shy about letting you know it's back there, but it's the tightest unit out there this side of a spool.
USA Standard Gear Powr Lok Positraction for Chrysler 8.75\" | ZP PC8.75-AGRS | RANDYS Worldwide
with them being an authentic reproduction - they are an all steel clutch design - and WILL require some time for the clutch packs to break in.
my recommendation is to get it up to operating temp, find an open parking lot - do a series of 20 low speed tight circles in each direction. ( not doughnuts 😉 ) this will scrub the steel clutch packs together and rapidly break them in.
you should see a dramatic improvement right away - and it will continue to get better with more driving - but again - these are an aggressive unit - and will occasionally chatter / scrub tires.
The question that hasn't been asked or answered, "Which one of the two Sure Grip units did you buy?"
Titan 1969
I had a similar issue when I had my factory sure-grip 3:91 diff pumpkin from my 1971 Barracuda rebuilt by 6-states. After many trips there and phone calls and two years of them saying just take to a parking lot and turn tight corners right and left and it will break in. I finally found out by researching there were different thickness on the spacers for the clutch packs it came down to what clutch pack kit you ordered. I called Dr. Diff and they sent me the proper kit and 6-states installed them for free and the problem was solved.
Here is the unit I purchased. I added more friction modifier and will take it for a longer drive this weekend and report back.
Yukon Dropout Assembly, Chrysler 8.75” Diff 489 Case w/Sure-Grip LSD, 3.91 Ratio​
Thanks but I'm not able to open the link - if that is one. My question is did you get the SMTH or AGRS unit? I'm assuming SMTH - but you know what they say about assuming...
Second trip out after adding +4 oz (8oz total) Friction Modifier did not seem to change any symptoms. So I decided to give it a more aggressive drive. WOW the 3.91 made a big difference for my stock 340 setup, even catch a "chirp" from 2nd to 3rd at WOT with stock 727 trans.
I may just need to break it in more, or this is just the way the diff is.
When Im coasting/still in motion 10 mph and make a turn, I get a moaning noise from the diff.
However Im at a stop and begin to make a turn, yikes...those clutches do not want to release...really holding both axles. The tire attempt to make the furthest distance in the turns, starts skidding as diff wont let go.
I am running the stock 14 x 6 " tires/ Poly's, so not much resistance from them :).
Ill report back if this goes terribly wrong or get better in the coming months.
