1974 Challenger Parts
cdummer43
Racine, WI
Challenger Rallye gauges with carbon fiber print bezel (can be removed) all Gauges work except for Tachometer, as it seems to be stuck. Even the tick-tock clock works, but it cannot be adjusted for some reason. Gauge assembly is being sold with the light bar above the lights but NOT the switches. (pics) $700
74 Challenger Black R&L Kick panels. (no holes excellent shape) $75
74 Challenger Battery tray $15
NEW! Challenger Window Washer can and motor $75 (yearone stickers still intact)
74 Challenger Front Bumper guards $50 for pair
74 Challenger Hood Hinges R+L (yellow) $100/pair
74 Challenger passenger side Front Bumper Filler $50
Challenger glove box door $40
Flush Challenger twist off gas cap $25
74 Challenger Rear Bumper guards $50 for pair
74 Challenger Rear Bumper (core) $20
ENGINE PARTS!
**The #’s after the description is the stamped # (outside of the head, inside head by rocker arms/ same but for the opposite head)
- RB Cylinder heads 1973 440 (orange) – 2406516-9 10215 / 2406516-10 09095 $150 for pair
- RB Cylinder Heads 1968 440 (blue) – 4006452 3665 / 4006452 3505 $200 for pair
- 2x Rallye wheel center caps $15 each
Pictures upon request!
**Buyer pays for all shipping costs, small or over sized!**
I will also be selling a 727 Torque flight as soon as my new 5-speed gets here as I will post pictures of that when the time comes, but I can also pull it out before hand if someone is seriously interested...
The "-516" cylinder heads appear to be 1965 361/383/413/426W closed-chamber castings, all performance levels, originally 2.08/1.60 valves. The "-452" heads should be 1975 400/440 open-chamber castings, all performance levels, originally 2.08/1.74" valves, w/hardened valve seats. Your pricing is spot-on; it's reasonable and the '75 heads are much better performers than the '65 parts. Just an FYI.
Thank you for the correction!
Do you have the rallye a/c control? I didn't see it listed though thought you might have since it usually comes with the rallye gauge package! Thanks Chris
Hi I sent you a pm on the trans can you give me some info about it ?
PM Sent I forgot to ask about the kick panels. Still got em??
