dodgerebellion
							Double vent... no cracks in housing but mounting screws will need some TLC to remove. All louvers are intact.  Right vent works fine. Left vent needs the metal bar that attaches all the louvers.  Included is a spare vent to replace that one or just use the metal bar.
Single vent...no cracks in housing but right side screw housings has a split and the mounting screws will also need some TLC to remove. The little housing tab for the vent shut off is not broken. All louvers are intact but needs the metal bar that attaches all the louvers.
Included is a spare cracked housing but has a good vent to replace the other one or use the metal strip.
There is also the dash duct that goes to both vents. More pictures available if you need.
$325. or offer. plus shipping from 60531.
I will also be heading to Mopars on the Mississippi Aug.24.
