Help with rubber fuel lines.
Ohiowoodchuck
Does anyone know the measurements for all the rubber lines on a 74 cuda. I can’t seem to find anything online. I’m looking for everything that would connect the steel lines to the fuel sending unit. The 90 lines on the fuel tank vent and I need to connect the fuel charcoal canister. I don’t think these are being reproduced. I heard from a reliable source that there is someone out there who does factory restorations that there is a list with the lengths hose type etc. hope someone can help.
I'd give Inline Tube a call and talk to them about your needs.
800-385-9452
Are you looking for precise lengths? Or exact reproductions of the rubber tubing down to the stenciling on the side? I don't recall there being a specific car-judging criteria on the lengths of the rubber tubes. If you want to know diameters, sure. Those are indeed documented, or at least the diameter implied being a function of the hard line diameter they connect to. But the lengths I've always thought were "cut to length" kind of thing-deal.
For some reason I was thinking the lines that came out of the tank and went to the vapor separator where more of a 90 degree formed hose than it was a straight piece. That’s why I was asking. Not looking for concourse just the correct hose if indeed they were formed to a 90.
