Is that the valve knocking?
Mopewbie
Ash Vale, England
The noise is getting louder, is that a valve issue?
Here's a slow motion video where one can see/hear it exactly when the #1 intake goes down. What do I need to do here?
Thanks.
I'd pull the intake and check out the camshaft lobe and lifter. Should be the third line from the front (first two lines are exhaust)
Wow, sounds like a knock and seems timed with the valve motion, but I've never heard a valve sound like that.
Thanks all. I'll need to replace timing chain anyway, will go with the whole lot of cam/lifters/rods.
Might just do the rings as well.
Right, nothing new so far. Since I was going to open it, I decided to flush the water system first because - why not?
Guess what? While the engine was running to temperature to activate the flushing, the knocking stopped!
I turned the car off, had the carb loosen already and then the coin dropped... turned the car on again, all good... so maybe it was just a lifter being funny?
I ran some tests rotating the engine and the timing chain seems fine as well so, apart from the old noise that I have no idea where's coming from, all is good.
