73 barracuda front brake lines,?
Flathead31coupe
Indianapolis
Passenger side brake line goes under the frame.My question is , does it go behind the gas lines or in front of the gas line.. Also, driver side brake line comes under the frame and comes up to the proportioning valve.Does it go in front of the master cylinder lines or behind them?Thanks
This is how I installed them which I think is correct. I used pictures I took when disassembling my car.
