The O ring grooves in the head can be filled with stainless wire and filed down so you can use standard gaskets. Just takes someone with the experience doing it. And probably some money.
Is the block still standard deck height? Have the heads been cut?
What would you do to your 'K' member to fit the Hemi in your car? Do you have power brakes? Have you priced headers/manifolds? In other words, have you thought through all the other things that it takes to actually install a Hemi in your car?
It is EXTREMELY difficult to build AND install a Hemi on any kind of budget. Just too many things unique to them and since they were typically raced, there are few good used and/or budget priced parts out there.
As long as the block's owner will lend his experience and advice, you have a shot at this. Otherwise, finding that experience and advice elsewhere will be difficult if not expensive.
If you do pull the trigger on the block, consider a lighter weight stroker kit. Hemi reciprocating assemblies were EXTREMELY heavy with all pieces being unique. More cubes don't cost any more money than standard cubes, take better advantage of the Hemi head flow making for a better, less temperamental 'driver', and using a new reciprocating assembly will save you lots and lots of headaches.
Good luck!
