Front and rear valance
Charlie71rt
Were the valances installed when E bodies were dipped in primer and painted with the rest of the car? Any body color over spray on the inside. Did they blackout the lower radiator support with the valance in the way?
anyone out there have any thoughts on my assembly line valance primer/ paint question?
I read in the past the blackout on the front was performed by a guy in a pit as it moved through the assembly line, he sprayed upward and it was a sloppy job.
No way they painted parts and assembled later, cars were painted fully assembled.
I've never heard of the body parts being dipped in primer, but it makes sense the supplier (to Chrysler Assembly Plants) would choose this as the most efficient method to prepare an order of valance panels for shipment.
As Katfish has said, the bodies were painted fully assembled. The pit guy spraying the black out would be focusing on the radiator support.
Having worked a few e-bodies in original paint, I can safely say the backside of the front and rear lower valance panels had little or no body color applied. I sometimes see light surface rust, there. By light, I mean unusually little, given the age or history of the car, and compared to other areas of the car. This correlates to their having been a factory primer protecting the metal as long as it was able.
I believe they were dipped in primer up to the roof line. Cars without vinyl tops were primed by hand. Then the whole car was painted. Vinyl top cars pretty much got next to nothing under the vinyl top except over spray during painting. Vinyl tops were applied after paint. Besides the vinyl trapping in water, the lack of primer and paint causes the usual rust problems on vinyl top cars which seems worse than on non-vinyl top cars.
Katfish is right, the radiator yoke on bright colored cars was painted by a poor guy in a hole spraying over his head. Must have been a miserable job!
I followed advise from Resto Rick. According to him, valances were painted off the car and the backside was fully painted body color. They were blacked out partially while the other front end blackout was applied. Most had only the center area covered.
Attached pic shows how I did mine. I used SEM Trim Black.
Will all due respect to RR, that just doesn't make any sense.
It was all about speed, why would they paint it separately and then assemble later?
Was the rear valance also painted separately, if not, why not?
Just think about the coordination involved, things were done in batches.
So they run to the storage area and grab a green valance when a green car was coming down the line?
You got me, no idea how things came down the line and through the paint booth. (honestly, not a snarky response). I’ll have to dig up pics I found of original valances. I remember seeing similar patterns on unrestored parts so went with that.
Thanks guys great info, so doors fenders and possibly/probably valances were bolted on before dip. Not much room between the front valance and radiator core support on a E-body to shoot paint up from a pit. No wonder they were sloppy.
Current eBay auction of an original paint Challenger front valance. Body color on what appears to be the entire underside.
Pardon Our Interruption...
To Katfish’s earlier comment about the extra work involved painting the valance separately. Wouldn’t there be an equal amount of extra work painting the valance on the car, then removing it to install the bumpers?
I agree that it’s unlikely there were stacks of painted valances grabbed off the line. I do believe the cars were painted in batches. Perhaps there was a fixture holding loose parts like these that moved along with the cars during the paint process?
As for the blackout, I’m aware of one theory that the front valance was bolted on loose, using only the two outer-center mounting brackets, allowing the valance to hang down during the front blackout application.
My '74 valances appear to be similar to that in the pictures above. Mine have original color overspray in many places, but it is not covered enough to say it was deliberately painted on the back side. The unpainted areas do have very light rust on them which would indicated some sort of sealer may have been on them after stamping, but they for sure aren't entirely painted.
I just saw this reference to valance painting in another post about the Chrysler assembly line process. A very interesting read focused on SUPERBIRD production:
“…For color-coating, the valances are hung with short wires from the roof rails inside the passenger compartment, and painted there by the workers while the car was in the color paint booth. (This was a later standard practice on cars with bolted-on front or rear valance panels).”
Here’s a link to the @ChallengerRTA’s post:
Assembly line
I’m just fishing around for more opinions on when the valances were installed pertaining to the paint process. I have an under coated (J55?) 71 so I thought I’d see if the gas tank had under coating behind the valance, it does not. So I removed the tank with the valance installed, it can be done but the bolts seem hard to get to for an assembly line. Then I realized the springs would be really hard to install with the valence on unless they put the rear in first. Any thoughts? Just curious thanks Charlie
Actually it just hit me if the valance didn’t have the exhaust tip cut outs it would be pretty difficult to install the the fuel tank after the valance.
Any thoughts on gas tank and rear springs being installed at the factory with the rear valance in place? Again asking opinions if the valance was in place when the whole car was painted.
