73 barracuda fuel tank vent line location pic needed.
Flathead31coupe
Indianapolis
Looking for a picture that shows the metal line from the tank vent.How it comes up on the passenger side and attaches to the inner fender , next to the windshield washer fluid tank.. Thanks
Here is what I got from my 74 manual. This is how I done it.
I have got those pictures already.Thank you though I appreciate them.. I was trying to see how the metal line runs up the inside of the inner fender , beside the washer bottle..
I can maybe give you a little insight using my 72 Challenger. The canister bracket was originally mounted on the inner fender just forward of the washer bottle. There are 3 nut inserts mounted in an upside down Y configuration on the inner fender panel. I moved mine around 90 degrees to the radiator side support panel to use a non-Ebody charcoal canister bracket. The canister is still in the same area as it was originally. I looked on computer at the engine bay photos for a 73 Barracuda and the line and canister location looks the same as a Challenger.
Terry W.
Terry W.
Thanks a bunch
