NEED FILLER NECK TUBE MOUNTING BOLT SIZES
dennispsalm91
Palm Coast FL
Ok after finally wrestling the filler neck tube into grommet/gas tank, can anyone tell me what size the 4 bolts/screws are that mount the filler neck tube to quarter panel. Im going to install the after market flip top cap. Thanks ahead of time
I will look at mine tomorrow and update, unless someone else knows for sure.
#10-14x.65" long Pan head Phillips.
For those with a 70-72 Barracuda/Cuda a little shorter screw with captive washer. 73-74 are shorter yet with no captive washer.
I listed Challenger first as he stated quarter panel. Then listed the Barracuda/Cuda for our Plymouth friends. If your original holes are trashed, go the route @Adam went. And yes, there should be a thin foam gasket in there.
The filler tube is aftermarket, im gonna check threads tomorrow. I thought one of the last cars i had, had screws in there. Unfortunately this car was unassembled
