Project Slantfish nearing completion
slantfish
Craig, CO
I'm finally closing in on the finish line. This was my dad's that he bought in '73, parked in '87 and I rescued in '14. I tore it apart and did a complete nut and bolt restoration on it, kept the slant 6 (upgraded it though), upgraded the 3spd to a 4spd OD, upgraded to disc brakes, upgraded to an 8.75 sure grip. It should be on the road in time for it's 57th birthday on 8/20
Looks great!
Whose under dash AC system did you use?
I went with Vintage Air, after seeing a lot of other posts it seemed to be the easiest to install with less hassles and minimal mods.
Since I refuse to buy a new car (sick of all the electronic bs, huge ass touchscreens and the new government mandate to allow anyone to remotely shut off your vehicle), this is absolutely going to be my new daily-ish driver, I plan on putting thousands of miles per year on it and need that AC for comfort.
Did you mil the head .100 , I did , made a huge difference !
.030 overbore, .030 off the block, .060 off the head. Head I did a mild port/polish and gasket match, standard size valves but I had them back cut, 340 springs with comp cams retainers - 48cc chambers. Entire assembly balanced (I'm pretty shocked at how much material was removed off towards the front of the crank versus the rear).
Deck clearance .163 with a gasket squish to .02 should put me around 9.25:1
JP billet timing set, Dutra RV10 RDP cam, Flowkooler water pump, rebuilt OE oil pump, Offenhauser 4bbl intake, Edelbrock AVS2 500, Clifford headers, distributor setup for HEI, ARP head and rob bolts. I also did a lot of grinding to remove casting from the water pump area and oil pump passages for better/smoother flow
Today it officially moved on its own.
Smooth running, starts immediately every time. I installed a 16:1 manual steering box and it's definitely an improvement, but still have to strong arm a 3pt turn a little.
Yesterday was the day for my final VIN/roadworthiness inspection. It passed with flying colors, so now I can officially get my plates and get it registered. 🎉 Just a few more weeks to button some things up and get it resprayed properly (the paintwork I had done last year was a **** job) and then I can drive it home.
Thank you @slantfish for keeping the mighty slant six alive!
Side note I've mentioned before, the Chrysler slant six is the only engine that went from automobiles to industrial vehicles with zero changes!! 😁
