plummmp
Hey guys, I’m in the middle of updating my 1970 Cuda grille. The current one is painted black like the AAR but is the non AAR grille. It has some melt, parking lamps need love, and it’s worn.
Anyways, I’ve painted the new grille dark argent and satin black, the red line and Plymouth emblem is installed, the chrome trim is on. It all looks good.
I’ve ordered the parking lamp mounting hardware and it should arrive soon. I’m now trying to figure out the best and safest way to mount the new grille.
I can’t find clear answers so hoping you awesome folks can advise me appropriately:
1. Do I need to remove the bumper in order to install the grille? It looks like it will wiggle in without removal but I’m curious if it’s worth removing to access lower bolts and have more room to work?
2. Should I install the new parking lamps after the grille is mounted and in place? Or install before putting the new grille in?
3. I plan to test the Holley retrobrights and parking lamps before installing anything. And also use dielectric grease on the grounds and connectors as they have some slightly weathering. Any other electrical considerations?
4. I purchased an all new grille mounting hardware set. From research some of the pieces seem to need slight modification in order to fit well (specifically the black spacer pads need to be thinned down a little for the bolts to reach through - not sure exactly what they’re called). Will verify measurements against the parts in there now when I remove everything.
Anything I’m not thinking of or additional tips to make this go as smooth as possible?
Thanks in advance!
Thanks in advance!
