		1970 Cuda parts
Left and right hand trunk extension panels, new from AMDnever used ($ 130 each new)
Convertible spare tire hold down bracket new from AMD, Trunklock shield new from AMD
Front jack hold down bracket new from AMD $300 for allpart# 54-57
1970 Factory Tachometer, correctly restored and calibrated,looks NOS ready to install and use in your ralley dash e body $400part#58
1970 Cuda outside door handle set, original factory parts notreproduction, very good used condition, no pits, no rust, no broken springsclean good overall condition $115 for the set of 2part# 59
1970 Cuda factory am 8 track thumbwheel radio, in goodcondition was working when car was parked years ago, is complete and in goodcondition $600 part# 60
1970 Cuda rally dash left hand corner side, this is thesection where the headlamp switch and convert top switch are located, goodcondition, woodgrain a little faded in 1 spot no broken studs,good switch mounts, nice piece(no metalswitch holder) $60part# 65
1970 Cuda front leading edge of grille stainless trim, 1 longupper piece very nice original part, no dents no bends polished up very nice$65part#78
Hemi K frame correct mounts, correct skid plate, sway barmounts locates hemi engine in factory correctlocation, no scraps, dents bashes or wrecks, powder coated silvermetallic $550.00part#11
1970 440+6 K frame with correct skid plate, no dents smashesor scrapes $ 375part#12
1970 3 speed wiper motor, functionscorrectly, is a bit dirty but otherwise good condition, complete with wiringharness, correct 3 speed wiper pivot arm on motor and includes a NOS 3 speedwiper switch still in original box $250part#13
1970 Hurst pistol grip shifterboxUsed but very good condition, box istight,Box is correct bayonet style 7174stamping box only $295 part#15
1970 Hurst pistol grip shifter box,fresh rebuild from Hurst, Box only $400.00 part#18
1970-71 Hemi valve covers correct wrinkle finish, correctwire looms correct breather and PCV provisions, correct baffling underneath,these look NOS but are modified 69 units, very well done, flat sealing edges,once installed no way to tell the difference nice set of hemi covers $600part#29
1970-71 HEMI engine pulley set, factory steel pulley set fora 70-71 HEMI engine with power steering, upper water pump pulley is used butgood condition not bent, no rust, runs true, lower double pulley is new( looksNOS) never mounted, has slight bend in edge of smaller pulley groove, veryminor, otherwise like new, flat edges, true running pulley grooves, clean notbent or out of round correct spacing of pulley grooves, alternator pulley iscorrect for 70-71 HEMI alternator, NOS never used, large upper pulley is morecommon 440 water pump pulley but was removed from an early 69 HEMI GTX with noPS(?) used but good condition, runs true no issues, check prices elsewhere onrepo stuff, great package deal if you need a real set of HEMI pulleys $375part# 71
Manciniracing reproduction RB/HEMI 6 qt racing pan (MRE884AB) new in box never used,$115part#81
Prices do not included shipping; prices are negotiable onmore expensive items, contact me for pix
