SOLD 1971 OE cuda shaker hood with ring, OE but modified bubble
mattsmopars
Cookeville, TN
1971 cuda original shaker hood, with original ring still installed. The hood is basically a rust free part. It does have some damage to the passenger front corner on the edge, and a fuel gauge was added to the rear of the hood and between two of the grille areas it was spread apart to allow the hose to pass through. There is also one spot under the bottom that was cut out for clearance.
Also included on the sale is an OE shaker bubble and OE hemi base plate that have been molded with fiberglass together to make one piece so it could be removed as an assembly. When looking down inside the bubble you can see the part number still present. There are no grilles inside the bubble and it looks like a portion of the mounting point has been removed for them.
I do believe the bubble can be removed or separated as you can also see the bottom edge when looking inside the scoop.
These parts have been put up inside for many years, and were on a race car and modified years ago when it was not a cardinal sin as it would be today. If you have any question please send me a PM. SOLD PENDING PAYMENT
