Gen 3 Cuda
- Joined
- Mar 25, 2018
- Messages
- 38
- Reaction score
- 8
As title states. I bought the car in as seen condition. Only thing I have with it is store it for four years. Real deal H code automatic. Has complete factory front suspension with sway bar. Engine and trans are long gone. Has 8 3/4 rear axle with Richmond 4.10 gears and spool, Moser 31 spline axles, Green bearings. Springs moved in. Has ladder bars with floater cages. Has had quarter skins installed. Installation looks good. Has rust that needs repaired on passenger side back window next to Dutchman panel. Have the back glass and trim. Cowl has rust that needs repaired. See pics. Right inner fender has been re welded in place. Windshield is factory glass and good. One piece fiberglass front clip with lift off hood. Doors are fiberglass with Lexan. Have loaded steel doors to replace or go with. Only interior is a bare dash frame. No gauges, no trim, no pad. I do have the VIN plate. All work done was by two previous owners. Subs and floor pans are in great condition. Rear wheel houses are not cut. Roll bar is bolted in and easily removed. Sub frame connectors should be cut out and re done or left out if going back on the street. I don't need to sell, but, I've had it this long and done nothing with it. It is stored indoors. I don't want to cut it up for a drag only car. Title is clear and in my name. For the car as it sits, the pair of loaded steel doors, and inner quarter trim panels, I'm asking $8500.00 OBRO. I don't post here much. You can check my feedback rating on FABO under 408swinger. Car is located in NW Iowa. PM me here for any questions. Thanks, FEBO!!!!
