FOR SALE 1974 Dodge Challenger Rallye
Cmuller0420
360 with a 904 slap stick auto setup currently. Panther pink with black interior. Body is very clean overall and in good cosmetic/mechanical condition. Not numbers matching but period correct 74 LA block
highly optioned 2 fender tag car - originally 360/4-speed from factory, rally red with white vinyl and white interior, rally dash, front disc etc. - probably a pretty low production car with these options from 74.
have most parts to bring back to a 4 speed - newer aluminum case 833, pistol grip shifter and rods, pedal assembly, bellhousing.
older restoration so paint is showing its age with little blemishes, nicks etc.
stock 360, 8.25 rear end with 2.94 gears.
recent work includes: new 750cfm carb and fuel system, wiring harness in engine bay, pitman arm, tires, windshield, brake work, wheel bearings, etc.
needs some minor things done:
-Interior door handles adjusted (hard to open so use outside handle).
-Mirror gaskets (have new ones)
-Aftermarket gauges installed (have new ones)
-Glove box inside (have new one)
-Washer pump (old one stopped working recently)
-Heater fan (have vent system apart to troubleshoot)
-Front dash speaker
-Trunk seal (bit of water got in last year and the rubber mat held the moisture under creating a bit of surface rust on the trunk floor.
have lots more photos/video and more info for anyone who is interested.
currently insured and in good running condition.
asking $20k USD/28k CAD O.B.O.
can call/text 250-515-5775
located in Kelowna, B.C. Canada
