SOLD 30 lb cylinder of Original Mopar R-12 refrigerant/freon brand new
krazykuda
I have two full never used 30 lb cylinders of Mopar R-12 refrigerant... Not aftermarket brand, but true Mopar... I have had these since the early 1990's sitting in my basement before R-12 was discontinued....
This is what you need if you want to restore your original Mopar A/C car with the original R-12 A/C system and make if function at its best performance, R-134A is not as efficient...
Asking $3500.00 each or best reasonable offer... Pick up only from south Chicago suburbs...
krazykuda
Pictures of cylinders on a scale...
Cylinder #1:
Cylinder #2:
krazykuda
Mopar freon? Who knew???
These were used by OEM's to fill the R-12 back in the day for testing... Hence the "For Professional Use Only" on the side of the tanks that you can see in pictures #2 and #3...
Bret Schneider
"Liquid gold"
Or gaseous gold depending upon which side of the expansion valve you're talking about :)
Back when those cylinders were filled they could be purchased for around $25 bucks with the Freon billed out at around $1 a pound. Guess I should have stocked up...
