Moparnascar
I need a pair of carbs, and a correct coded intake or a correct aluminum intake. I have a original 440-6 V code Automatic car I am restoring. Car Build date is 9-3-1969 so i would like the dates earlier than that. I need a center carb 4376, rear carb 4383, front carb 4382. I also need a correct date coded 440-6 auto distributor.
I have been collecting parts for some time and I hae some stuff to trade or sell to make this correct.
10-30-69 cast iron intake
front carb 4382 2278 code
center carb 4375 3029 code
rear carb 4365 2278 code
looks NOS 1971 440-6 dual point dist #3436577 with vac advance #3438351
and a used 1970 340 dual point distributor #3438317
1-3-1970 cast date 440 HP block
1970 date 440 4bbl intake
9-69 1970 340 block
4 340 J heads
2 906 440 heads
set of 8 original 425 hemi rods
Thank you, William
9-69 1970 340 block
4 340 J heads
2 906 440 heads
Thank you, William
