440 engine mounts?
bigter33
West of Chicago
This project is a full resto and I'm going from a small block to a 440 in my 70 challenger, do I need special engine mounts? If I do where is the best place to get them? Do I need to modify my K frame? Thanks for the help...
once you have the correct brackets to mount the engine which you can buy new or used you have a choice of the mount pads , I have used the interlocking poly mounts which will not pull apart & fail like the original rubber mounts
