73 barracuda aftermarket quarter panels...wheel opening trim?
Flathead31coupe
Indianapolis
73 barracuda with aftermarket market quarter panel install.. The factory wheel open trim does not fit at the lower section of the quarter panel in the rear.. it looks like the aftermarket quarter panel is straighter at the bottom inside corner than the factory is more curved like the factory trim....If you buy aftermarket trim , will it be closer to fitting... thanks
About 3-5 years ago, I installed OEM (used, but repolished) wheel lip moldings back onto a 1970 barracuda with AMD rear quarter panels installed. we used the original rear lower valance (with exhaust cutouts) and replaced the trunk floor pan. all those panels had to be tweaked a little bit to fit precisely (well, more precise than factory) , but nothing major.
Later, I seem to recall the wheel lip moldings did not initially fit precisely as they did on the original quarters. but then, they were removed and stored about 5 years prior, so it's hard to say if during storage, they underwent some tweakage. With minimal effort, I was able to bend and tweak those moldings so they laid pretty flat and even, PRIOR to applying the screws. we chose to drill pilot holes, once the trim laid flat and looked good.
I may have spent 2 hours dry fitting them, prior to screwing them in. the first one took about twice as long as the last (I started to git gud)
so in your case, an image showing how far out of whack it is, could help us judge if it needs tweaking, or something else is awry. in the end, they may look just fine, even perfect, if you can get them to follow the contour you presently have.
don't mix them up. I think each of the four is a little different. I'm gonna hit the dealer parts book, to confirm. but these were "a package" so I'm uncertain I'll find the part numbers for each part.
semi confirmed.
I recall reading a thread somewhere which showed tweaking done to the moldings.
One guy used a shrinker/stretcher on the flange while another guy made pie cuts in the flange.
I have rear factory quarters, and i bought aftermarket moldings. It's been a while but I remember them fitting pretty good. Only slight massaging them to fit well.
They came from year one at the time.
I replaced my wheel lip moldings 20 years ago and the only way I got them to fit was to make some cuts in them so they would conform to the original quarters. Seems like the rear part of the rear ones were off the most. But, after all these years they are still on there, look good, and I have never had anyone comment on the cuts. I was pretty hot at first when they didn't fit and I had to cut them. But, over the years more and more parts have required modifications to fit (if they could be made to fit at all) so it has become something I have gotten used to. But is still annoying as hell.
