Mar 3, 2017 #1 W Winnie Member Joined Mar 3, 2017 Messages 5 Reaction score 0 do you need to use a copper washer between the screw in brake hose and the disc caliper or can you just screw in the brake hose. Thanks
Mar 3, 2017 #2 J js29 Well-Known Member Joined Aug 5, 2012 Messages 671 Reaction score 152 Location lee center ny 13363 You need to use A copper washer on each side of the banjo bolt.
Mar 3, 2017 #3 W Winnie Member Joined Mar 3, 2017 Messages 5 Reaction score 0 js29 said: You need to use A copper washer on each side of the banjo bolt. Click to expand... no banjo bolt is used with this setup, the brake hose just screws in the 73 Cuda caliper.
Mar 3, 2017 #4 J js29 Well-Known Member Joined Aug 5, 2012 Messages 671 Reaction score 152 Location lee center ny 13363 Sorry i did not know that, but I still be-leave you need A copper washer.
Mar 3, 2017 #5 S Steve340 Well-Known Member Joined Sep 19, 2016 Messages 1,107 Reaction score 498 Location New Zealand js29 said: Sorry i did not know that, but I still be-leave you need A copper washer. Click to expand... He is right a close fitting copper washer is required to seal the threaded brake pipe fitting in to the caliper Take care to get the right ID and OD sizes.
Mar 3, 2017 #6 340challconvert Well-Known Member Joined Feb 13, 2011 Messages 5,540 Reaction score 2,983 Location Parsippany, NJ I bought new brake lines and new front calipers. The copper washer came with the units.
